show variable at set times
vraimondi
Post by vraimondi »
Dear all,
I am quite new to vensim, and am struggling with the following:
I have a variable whose values make sense only at set times (that is, when time = integer(time)), so I need to show only those values on a graph and then would like to interpolate between the showed points (so that the plot looks like a graph rather than a series of dots). Is there a function that I can use? I have attached a file showing the actual and the desired (to be shown) behaviour.
Thanks for your help,
Vittorio
desired graph example.pdf
(71.71 KiB) Downloaded 797 times
By far the easiest solution is to just set SAVEPER = 1 in the model settings dialog. Then everything will show up only on integer times. If you don't want this use
measured var = IF THEN ELSE(Time = INTEGER(Time),var,:NA:)
And the graphs will look right.
Bob Eberlein
Pruyn
Post by Pruyn »
You could also use the sample if true funtion. This will hold a value untill the test statement returns true.
measured var = SAMPLE IF TRUE (Time = INTEGER(Time),var, var)
depending on what you want
vraimondi
Post by vraimondi »
Thanks to you both for your help and for taking the time to do so!
I decided to use the if then else function with the :NA: and it does work (I thought I had tried this one and it was not returing any result, but clearly must have done something wrong there).
As I was attempting to find a way to fix the problem, I noticed that it is not actually possible to create a custom bar- graph through the control panel, and the only way to create one is through the vgd file as text - but then the manual was not too helpful, only a few commands are mentioned - . Is that true?
Custom bar graphs do need to be created via a text editor. Details on the commands are in chapter 15 of the reference manual - look for Bar Graph Tool Keywords - there are quite a few.
