does anybody know, why I got lines (like arrows, whithout head) in a printed sketch, while they don't appear in the sketch. How can I solve this problem?
I am working whith DSS 5.3.
Peculiar lines in a printed model
I guess these arrows are hidden in your normal view.
Next to the view selectorbox at the bottom of the screen there is the hide level select box. Normally you will see a box with the text hide in it. Click it and select show all. This way all items in a view are shown.
Now you can delete the extra arrows.
This can happen if you remove items from your view, but not from the model.
Jeroen
Jeroen
There are curves and they do not connect anything. On the printed page it seems as if they come from the left outside into the sketch in form of a curve almost to the right side, leaving the sketch again on the left side. I have tried to another printer but it does not fix the problem.
This very strangely curves dont appear, if I copy and paste the sketch in Word and print it therefrom.
What operating system and what printers?
I suspect this problem is occurring because some of your arrows are almost, but not quite, straight - you are probably seeing an echo of the arrow that should exist.
Try making a small sketch to see if the problem occurs there - if so post it and I will take a look.
It was a good piece of craftsmanship but finally I found the reason and the answer to the problem.
As you mentioned in your reply, Bob, the problem occurs when an arrow is almost, but not quite, straight. Even though all arrows appear in the model sketch, it can happen that the line of one arrow doesn’t appear in the printed sketch, only its arrowhead and that strange line across the printed sketch.
To fix the problem, you “just” have to found that arrowhead without a line between two variables in the printed sketch (a tricky job in a wide sketch) and then modify the curve of that arrow in the original model sketch.
Thank you, Bob, for your hint.
