Run a GAME!!?? -->Test Inputs??
Till
Post by Till »
Hi!!
I have a model for that describes the influences on the contact rate. One of these influences should be the advertising spending. Now I tried to define the variable as "Gaming"-variable, so that one coul simulate the influence of a changing advertising budget.
When I click the button "Start GAME" and vary the advertising spending it doesn't work because there are "no test inputs"!?
Is not the "adevertinsing spending" the "Test Input" in this case??
PS: See the added model!
Thanks for your help!!!
regards till
advertising.mdl
(1.8 KiB) Downloaded 511 times
My best guess is that you clicked on the Reality Check button and not the game button. Otherwise you would not get that message.
Till
Post by Till »
Thank you! That was the problem!!!
regards till
