SWITCH(a,b,c) of DYNAMO II --> in VENSIM?
thommyp
Post by thommyp »
HI,
can anyone tell me what would be the Vensim equivalent to a DynamoII SWITCH() Function. Explain me how it functions?
Thanks a lot
Cheers
Thomas
I have no experience of Dynamo, but if you can tell me what the function does, I can probably tell you how to do it in Vensim.
SWITCH is the same as the dynamo function FIFZE (FIrst IF ZEro) which is the same as IF THEN ELSE except that the second and third arguments are reversed - that is
SWITCH(a,b,c) matches to IF THEN ELSE(a,c,b)
thommyp
Post by thommyp »
Thanks a lot, I wasn't sure which argument is related to the true condition.
