Thanks for the help with the other stuff I have also got some queries on one other thing, I have attached a copy of the model, it is something simple like the syntax of the respcetive epxpressions yet the model does not behave as planned. If anybody can glue me in then i would be greatful. the system is supposed to represnt the net capacity of a entity to absord waste, ie. the inital net capacity, the net rate of recycling and the net rate of fill. It doesn't seem to work.
Yours sincerly
Julian
it is actually part of a bigger model, but if I can get the hang of the basics then I hopefully I shan't have too many more issues
The Basics
The Basics
- Waste Mitigation.mdl
- (1.67 KiB) Downloaded 537 times
The basics
if the arrows on the sketch are right, the formula is wrong and should be like in the model joined
- Waste Mitigation_2.mdl
- (1.67 KiB) Downloaded 563 times
