random uniform
gastoncoma
random uniform
Post by gastoncoma »
Hi guys, trying to understand the way of using this random uniform equation.
I understand that:
RANDOM UNIFORM( {min} , {max} , {seed} )
min is the minimum value and max the maximum value. For example 0, 1 but what is the seed thing about??? It's driving me creazy as I read the help and it obviously doesn;t help me at all!!
I don;t need any third number, I just want a random number between 0 and 1
The noise seed is useful when doing monte carlo simulation. Just create a parameter called NOISE SEED and set it to any value and use it in all RANDOM *** functions.
gastoncoma
so what value should I use? a zero, a five, any number?
Lee Jones
Post by Lee Jones »
If you are using NOISE SEED in the model, set the value for "seed" in random_uniform to "0"
Always set the last argument (which is actually a stream ID not a seed) to 0 unless you have a specific need to create separable random number streams (a rare requirement). Add the constant NOISE SEED to the model if you want to select different noise realizations for sensitivity simulations or other reasons.
