Error in model
mawajed
Error in model
Post by mawajed »
Hello
Can anyone tell what is the meaning of this error
" Floating point error computing - spread through contact - at time = 6.000000"
I am trying to run my model but this does not work
Thank you
Often it is because of a divide by zero. Is this the case in your model?
mawajed
Post by mawajed »
Hey Thanks a lot I will keep that in mind and go through the model again
Hopefully i should find the problem
Have a look at the equation for "spread through contact". If it has a division, check that it is not zero.
