Call MATLAB function from Vensim(Vnext.c)
khalediwm
Post by khalediwm »
I need to call 'fsolve' function of MATLAB in my Vensim (Venext.c) file. Actually I am using external function facilities of Vensim to do some optimization. Previously I was working with IMSL library but it seems very difficult now a days. Therefore I like to use 'fsolve ' function in my Vensim model. Could any of you please help me to use 'fsolve' function, in my venext.c file.
You need to use the Matlab api to call it from C, per http://www.mathworks.com/access/helpdes ... 38569.html
This is probably not a simple task.
I think Vensim's FIND ZERO function is basically the same as fsolve, so you may be able to do what you're trying to do without Matlab in the loop (which I would highly recommend if at all possible).
What are you trying to accomplish?
khalediwm
Post by khalediwm »
Thanks for your valuable suggestion.
I am trying to solve a system of nonlinear equations for my reseach purpose. It has 26 variables and 33 parameter values and these parameter values are time dependent. It would be very helpful if you can please show me how to write a simple problem, so that I can try with my larger equations. I am also copying my sets of equation, so that you can have a look and give me your valuable judgement whether FIND ZERO function would be helpful or not?
z(1) = exp(Y) - OMt*At*K.^alpha*L.^beta*exp(E).^(1-alpha-beta);
z(2) = alpha*L*exp(w) - beta*K*exp(r);
z(3) = alpha*exp(E)*exp(Pe) - (1-alpha-beta)*K*exp(r);
z(4) = exp(Y) - exp(r)*(K) - exp(w)*L - exp(Pe)*exp(E);
z(5) = exp(E) - (gamma*exp(Eh).^theta + (1-gamma)*exp(El).^theta).^(1./theta);
z(6) = gamma*exp(Pel)*exp(Eh)^(theta-1) - (1-gamma)*exp(Ph)*exp(El).^(theta-1);
z(7) = exp(Pe)*exp(E) - exp(Ph)*exp(Eh) - exp(Pel)*exp(El);
z(8) = exp(El) - a1*exp(Fe1) - a2*exp(Fe2) - a3*exp(Fe3) - exp(e4) - exp(e5);
z(9) = exp(El)*exp(Pel) - (a1*exp(Fe1)./exp(El))*exp(TCe1) - (a2*exp(Fe2)./exp(El))*exp(TCe2) ...
- (a3*exp(Fe3)./exp(El))*exp(TCe3) - (exp(e4)./exp(El))*exp(r)*k4 - (exp(e5)./exp(El))*exp(r)*k5;
z(10) = (exp(TCe1)*(1-2*a1*exp(Fe1)./exp(El)) + exp(Fe1)*exp(FC1)*(1-rho*exp(Fe1)./(PR1-exp(Fe1)-exp(Fh1)))) ...
- (exp(TCe2)*(1-2*a2*exp(Fe2)./exp(El)) + exp(Fe2)*exp(FC2)*(1-rho*exp(Fe2)./(PR2-exp(Fe2)-exp(Fh2))));
z(11) = (exp(TCe2)*(1-2*a2*exp(Fe2)./exp(El)) + exp(Fe2)*exp(FC2)*(1-rho*exp(Fe2)./(PR2-exp(Fe2)-exp(Fh2)))) ...
- (exp(TCe3)*(1-2*a3*exp(Fe3)./exp(El)) + exp(Fe3)*exp(FC3)*(1-rho*exp(Fe3)./(PR3-exp(Fe3)-exp(Fh3))));
z(12) = exp(Eh) - b1*exp(Fh1) - b2*exp(Fh2) - b3*exp(Fh3);
z(13) = exp(Eh)*exp(Ph) - (b1*exp(Fh1)./exp(Eh))*exp(TCh1) - (b2*exp(Fh2)./exp(Eh))*exp(TCh2) - (b3*exp(Fh3)./exp(Eh))*exp(TCh3);
z(14) = exp(Fh1)*exp(FC1)*(2*(1-b1*exp(Fh1)./exp(El)) - (rho*exp(Fh1)./(PR1-exp(Fe1)-exp(Fh1)))) ...
- exp(Fh2)*exp(FC2)*(2*(1-b2*exp(Fh2)./exp(El)) - (rho*exp(Fh2)./(PR2-exp(Fe2)-exp(Fh2))));
z(15) = exp(Fh2)*exp(FC2)*(2*(1-b2*exp(Fh2)./exp(El)) - (rho*exp(Fh2)./(PR2-exp(Fe2)-exp(Fh2)))) ...
- exp(Fh3)*exp(FC3)*(2*(1-b3*exp(Fh3)./exp(El)) - (rho*exp(Fh3)./(PR3-exp(Fe3)-exp(Fh3))));
z(16) = exp(e4) - a4*k4.^mu4;
z(17) = exp(e5) - a5*k5.^mu5;
z(18) = exp(FC1) - Pfz1*((PR1-exp(Fe1)-exp(Fh1))./Rz1).^rho;
z(19) = exp(FC2) - Pfz2*((PR2-exp(Fe2)-exp(Fh2))./Rz2).^rho;
z(20) = exp(FC3) - Pfz3*((PR3-exp(Fe3)-exp(Fh3))./Rz3).^rho;
z(21) = exp(TCe1) - exp(r)*k1 - exp(Fe1)*exp(FC1);
z(22) = exp(TCe2) - exp(r)*k2 - exp(Fe2)*exp(FC2);
z(23) = exp(TCe3) - exp(r)*k3 - exp(Fe3)*exp(FC3);
z(24) = exp(TCh1) - exp(Fh1)*exp(FC1);
z(25) = exp(TCh2) - exp(Fh2)*exp(FC2);
z(26) = exp(TCh3) - exp(Fh3)*exp(FC3);
symboles, which are within exp(), are variables.
khalediwm
Post by khalediwm »
I am eagerly waiting for your response, as I am fully stuck with my research at this point. It would be highly appreciated if any of you please show me a simple example of using FIND ZERO function. I couldn't get clear idea after looking at the Vensim Manual.
Fndzero example.
Here is a little example that uses the find zero function. The key thing is that the inputs and outputs need to be put into a vector, which means you might need things like
x[e1] = xb3
x[e2] = ml71
and so on assigning values to the vector elements.
findzerotest.mdl
(3.17 KiB) Downloaded 818 times
khalediwm
Post by khalediwm »
Hi Bob
Thanks for your response, especially at this curtail moment. Actually today is the last day for me to decide whether I will be using FIND ZERO function or not. I just stuck in following your instruction, may be due to the lack of knowledge in Vensim. I tried to solve a simple problem just to do some checking. Unfortunately, I was not able to build the model as per your instruction. I will be very grateful to you if you please have a look at the model (I worked on your model) and correct me.
Thanking you inadvance.
The equations are:
x+exp(x-1)+(y+z)*(y+z)-27=0
exp(y-2)/x+z*z-10 =0
z+SIN(y-2 )+y*y-7 =0
findzerotest.mdl
(3.93 KiB) Downloaded 778 times
here is the way you would do this - you need to map the x1 etc values to be elements of a subscripted constant.
This model does not converge. So if you really are trying to solve systems of the sort here the FIND ZERO function is not a good choice.
temp.mdl
(4.46 KiB) Downloaded 607 times
khalediwm
Post by khalediwm »
Thanks Bob, for your unconditional support. I am very much surprised on the performance of FIND ZERO function. The above 3 equations are non-linear but not very complex.
As per the advice of Tomfid, I thought that it would be an average catagory non linear equation solver like 'fsolve' of MATLAB. But, I just found that it could not move from its initial value! very starnge.
Thanks again
I should probably have actually taken a closer look at the model, not to mention the documentation on the FIND ZERO function. What I posted did not actually make sense, since solve was not connected to the computation of the equations. The new attachment does this correctly, and seems to solve without difficulty.
Note especially that your equations are not homogeneous of degree 1 as the pricing example is.
[Edited on 2010-9-2 by bob@vensim.com]
temp.mdl
(4.65 KiB) Downloaded 761 times
