Why there is a message said that "warning, at 2010.25 above- fertiliser lookup computing- effects of fertiliser on yield" when I run the model?
Is it because of the error with the fertiliser lookup?
Thank you,
nadia
Warning message
Actually I want to see at what amount of fertiliser that we have to add in order to get maximum yield. This is because the amount of fertiliser subsidy provided by the government is fixed and not enough. Therefore, farmers have to buy extra fertiliser in order to get maximum amount of yield. My equations are as follow:
yield= max yield*effects of fertiliser
effects of fertiliser on yield= fertiliser lookup ( fraction of fertiliser)
Fraction of fertiliser = (fertiliser subsidy+extra fertiliser)/recommended rate of fertiliser
My reference point is (1,1) which is the x axis will be amount of fertiliser and y axis will be yield.
x axis (1)=amount of fertiliser used must be same with the recommended rate of fertiliser
y axis (1)=max yield which is 10
Now I just put the maximum range is only at (1,1) because I only to see at what amount of extra fertiliser must be bought in order to get max yield. But this warning msg appear. Is that mean I have to put the range greater than 1?
Thank you.
Thank you.
In other words, this error is really just a warning. If it's OK that your input sometimes exceeds the bounds of the lookup (which I think makes sense in this case), then you can ignore it.
