Linking sliders not using VENAPPS
jv104
Post by jv104 »
Is it possible to link sliders for constants in a model without using VENAPPS?
I have 3 variables that are linked to one another:
1. Capacity of a service
2. Initial population using service 1
3. Initial population using service 2
These variables can be set using sliders. The initial population values should not exceed the "capacity of service" as they use they utilise the same capacity, but I can't make the value of the initial populations to depend upon the capacity of the service, so it is possible for the initial values to exceed the capacity which causes the model to work incorrectly.
Are there any ways to address this without using VENAPPS? E.g. showing a warning, or changing the bounds possible for the initial populations to be dependent on the capacity.
Joe
Re: Linking sliders not using VENAPPS
This will only work if you have the two populations, but why not have a slider for population 1, and then calculate population 2,
population 2 = capacity - population 1
Another possibility would be:
share 1 = ... (slider)
total population = ... (slider)
population 1 = share 1*total population
etc.
