SABLE Graph and selecting WBVAR
Moderator: Administrator
drees
Post by drees »
Hi Tony
When I set up a Sable graph everything is fine. However when I then ask it to select the workbench variagble it shows both axes as the variable value rather than the variable value on the y axis and time on the x axis. I have checked in the graph dialog and time is checked for the x axis. When I shift the graph to run a selected variable all is okay. It only occurs if I set it up to run the workbench variable. By the way running the latest version.
Cheers
David
Re: SABLE Graph and selecting WBVAR
This was another bug. A new build is now available to download with it fixed.
drees
Post by drees »
Thanks once again. Apologies for catching all your bugs!
David
Thanks for finding the bugs.
