trouble recreating vensim models in ventity
Benjamin Sprecher
Vensim version: Ventity
Post by Benjamin Sprecher »
I recently built a vensim model to explore base-metal and companion metal production. This seemed like a perfect model to translate to ventity, because there are a bunch of companion metal mines that have a identical structure but differ in a couple of co-production fraction parameters. I attached the model in this post.
I'm immediately running into trouble because I can't recreate the GDP growth loop (lower left corner of the vensim model). Is there a reason why I can't have auxiliaries influence stocks, and how would you recommend building this type of model in Ventity?
Kind regards,
Benjamin
Zinc model - MW.mdl
(19.05 KiB) Downloaded 845 times
Re: trouble recreating vensim models in ventity
Ventity is a little stricter about stock-flow methodology. But if you make GDP Addition into a flow, this should be doable.
