Sensitivity run
moudi
Sensitivity run
Post by moudi »
I would like to do a sensitivity analysis. I assume that the settings in the analysis (sensitivity) are correct, but I cannot see the results (see attached file).
Test Data Sensitivity.zip
(15.91 KiB) Downloaded 1273 times
Re: Sensitivity run
I think you just need to modify your run config:
Re: Sensitivity run
You don't strictly need the savelist, but you get a lot of extraneous stuff if you don't provide it.
