Dear Tom, Administrator,
I want to create a page in Venapp interface that allows the user to do a sensitivity analysis on any parameters that he wishes. Accordingly, I need to know how can I open the "Sensitivity Simulation Setup" window in Venapp by creating a button (or another way)? I looked in the manual and the forum, however, I could not find a solution! Could you please help.
Sincerely yours,
Hossein
Opening "Sensitivity Simulation Setup" window in Venapp
Re: Opening "Sensitivity Simulation Setup" window in Venapp
The following commands are used to specify the sensitivity files,
http://www.vensim.com/documentation/ind ... ?25365.htm
http://www.vensim.com/documentation/ind ... ?25360.htm
... but you can't launch the .vsc editor itself.
Dear Tom,
Thanks for your answer. Therefore, I should myself specify some parameters and their distributions in Venapp and user can just modify the Min, Max, SD,... Is there any way that gives freedom to the user that do sensitivity based on a chosen parameter and distribution, which are specified by the user itself?
BR,
Hossein
BR,
Hossein
The parameters of the distribution in the sensitivity control can be variables, and the user can set the values of those like other constants.
If you want the user to choose the distribution as well, you'd have to build that into the model. Then the user could set a flag to choose the distribution, and the sensitivity setup itself would just vary the random seed.
