Dear Tom/Administrator,
When I push the "Test Screen" and my model input window opens, there is no problem and all the boxes for input variables show the correct number. However, when I push the "Run Venapp", I got "error" for the same boxes! (please find the attached pictures). I would appreciate it if you could help what could be the problem?
BR,
Hossein
Test Screen vs Run Venapp
- Test Screen.png (73.8 KiB) Viewed 1867 times
- Run Venapp.png (72.9 KiB) Viewed 1867 times
Re: Test Screen vs Run Venapp
Can you upload the files? Screenshots are useless, we cannot tell anything that is wrong.
It could be that you have not loaded the model properly, or they are gaming parameters (but no game is in progress). Could be a number of different things.
Dear Administrator,
I found the problem but still need the solution.
I modified my model but the venapp model still reading the previous one! How should I define the modified one for my venapp?
BR,
Hossein
BR,
Hossein
The problem was solved!
I had mistakably loaded another model. By deleting loading that model, the problem was fixed!
