Generated code error
Jack Harich
Post by Jack Harich »
Another error. I expect that during my learning Ventity phase, there will be plenty of these, so I really appreciate your patience!
Generated code at (577, 76) Cannot convert lambda expression to delegate type 'System.Func<string>' because some of the return types in the block are not implicitly convertible to the delegate return type (context: initializing; reference voter_by_politician_supported, in politician)
The model is very young and has hardly anything yet. The problem relates to a partitioned collection. Thanks!
RDem 07 With error related to Voter collection.zip
(19.67 KiB) Downloaded 979 times
Re: Generated code error
Not sure what the problem is, but it's not the referenced count. Ticketed - hopefully devs will have an answer soon.
The error is defining the incumbent attribute as an integer 1 instead of a string "1". We'll catch this in the future.
However, you wouldn't want to make the incumbent attribute "1" because there is no politician with that name. It should be "P1" or something to match your data. I tend to leave the attribute default expression blank and instead define it in the input data.
