Polarity Font size and color
- Vensim version: PLE+
I am using PLE+ 10.0. In older versions, I was able to right-click on an arrow and change the size and color of the polarity sign. Can polarity font be changed in PLE+ 10.0?
Re: Polarity Font size and color
You still can do this. Is the sketch locked when you are right clicking?
I see it now! it's a little different. Had to unclick the default font button. Then click the font type and then the font option screen opens.
Hi, i try to change the polarity fontsize on arrows in vensim dss.
I right-click on arrow, click on courier which is the default and change size to 19. Nothing happens.
Any ideas what i do wrong here?
We know about this. Try setting it a 2nd time and it should work.
ok thanks, also the obvious thing would be to activate font and fontsize in the bottom panel once you select an arrow,
just like it is done for auxiliaries and stocks.
Alternatively a right click quick menu for polarity, font and size should do it.
The way it is now is just counterintuitive with font options for auxiliaries and arrows in different places.
Other than that, vensim improved since the last time I used.
