I am using Vensim DSS 6.1 on Windows 7.
I'm having a problem that I just noticed as of late. When I save and exit my model, then re-open it, some of the variables are not shown in the view but still exist as shadow variables (ex- if I search for a variable name it says it cannot find it in any view, but I can still place it as a shadow variable and then open it in the equation editor). My model still runs fine when this happens, but it's annoying because I cannot see how everything is connected. Has this happened to anyone else? Is there a way to retrieve it?
EDIT: I've tried pressing h, ctrlA, unhide but nothing pops up
Thanks,
Jordan
Variables Missing from View
Re: Variables Missing from View
Each Vensim view can have anything from the underlying model displayed on it. And you can also have a model that has new views at all. So it's easy to have a model with many views, and some parameters do not appear in any of them.
You will need to post the model and let us know what parameters you are having trouble with in order for us to assist.
My model is attached.
The following variables (are either level or auxilliary) plus their inflows and outflows are missing:
-Junction 94
-Junction 95
- Langdon Reservour
- Cowoki Lake
- Tilley Reservour
- Kitsim Reservour
- Snake Lake
- Rock Reservour
They should be in the view "Reservoiurs".
-Junction 94
-Junction 95
- Langdon Reservour
- Cowoki Lake
- Tilley Reservour
- Kitsim Reservour
- Snake Lake
- Rock Reservour
- NewModel_Oct27b.mdl
- (155.11 KiB) Downloaded 241 times
I can see the problem, but not sure how it happened. Do you have any earlier versions, in which they're still present on the diagram, that we could compare?
This is the most recent version, before I noticed this strange occurrence. I have not yet built 'Junction 94' and 'Junction 95' in this version, but everything else should be there.
- NewModel_Oct22b.mdl
- (241.54 KiB) Downloaded 225 times
The 22b version looks corrupted as well. Only about 10-20% of the first Reservoir view loads.
It's still not clear what the problem really is. The diagram is large, but I've seen bigger, so I don't think that's the issue.
Generally, switching back and forth between text and sketch view can cause small bits of structure (links, not variables) to drop out, due to undefined equations, but that's normal and wouldn't cause large chunks to disappear as here.
Anything unusual about your setup? Very large monitor? Doing diff/merge with source control tools? Mixing platforms or versions?
Do you have a still-older version to look at?
Here is an older version. There are many variables here that have been deleted (on purpose) before the newer versions. The left portion of the 'Reservours' view contains many variables linked together. This portion initially started out as an experiment, but got much too big so I removed it (I might look at subscripts and import a simpler version of it later). I haven't noticed missing variables in any of the versions prior to me erasing that big chunk of variables on the left, so maybe removing these has something to do with it. I'm not sure the connection though, since nothing I built in the latest two versions uses any of the deleted variables (variables I deleted on purpose, not the ones that mysteriously went missing), nor did I delete any shadow variables.
- NewModel_Oct15.mdl
- (407.6 KiB) Downloaded 240 times
The good news: I was able to restore the diagram from the Oct_15 version.
First, I edited to the 15 file to break up the large diagram into several chunks.
Then, using a text editor, I copied the new diagrams from the _15 file and appended them to the sketch info in the _27b file. Sketches start with
\\\---/// Sketch information - do not modify anything except names
V300 Do not put anything below this section - it will be ignored
*Reservoiurs
:TABLE Reservoiurs
:TITLE Reservoiurs
:PRETTYNUM
:FIRST-CELLWIDTH 30
:L<%^E!@
1:Current.vdf
9:Current
22:$,Dollar,Dollars,$s
In hindsight I possibly could have done a copy/paste directly from sketch to sketch, but this way I was sure that it would work without touching any equations. Vensim is fairly tolerant of defective diagrams - it just doesn't render variables that don't exist.
The inserted versions seem OK, except for all the deleted variables. Hopefully this will give you a basis for continuing.
Thank you!
Yes, I can now work from the restored model.
