WMF export not working with larger
kleemax
Post by kleemax »
First I want to thank you developers for implementing WMF export option (View/Export as WMF i.e. Windows MetaFile). This is quite helpful as it copies a vector image to the clipboard that can be used in MS-office applications.
I have a model with hidden structures. When I only show until hide-layer 15, WMF works as expected, but if I unhide more structures (hide layer 16 or all) then what is copied to the clipboard is empty (when pasting to MS-Word I get an empty picture that has almost no height (0.11cm) and is as wide as the page allows. This is funny: I show more but bet less, actually nothing...
Re: WMF export not working with larger
Can you give us an example model (or just the sketch)?
I'd urge you to use SVG instead if you can. I'm sure it will not be long before SVG is a recognized clipboard format.
