On the window of opportunity for forecasting
Locked
MacovL@aol.com
Post by MacovL@aol.com »
What if the forecasts are kept within boundaries predicted by past events.
For example, past events demonstrate a stable limit cycle or even chaos. Then
forecasting is possible if limited by known boundaries and accuracy becomes a
relative term yet useful for decision making.(?)
A more direct question: Are there useful and simple techniques for applying
stochasticity to a parameter? I have so far only used the Random function?
Are there other, better ways?
Lou
"Jay W. Forrester"
Post by "Jay W. Forrester" »
--============_-1302151624==_============
Content-Type: text/plain; charset="us-ascii"
The use of forecasting for guiding decisions is restrained by
considerations in the attached figure. Assume we know the past path of a
variable up to the present decision time. The immediate future is
determined by the "momentum" of the system, that is, by the slowness with
which conditions can change. The future is also affected by random events
that are not subject to being modeled in terms of specific time and
direction. Continuity, or momentum, keeps the economy from diverging
quickly from the present path. In the figure, forecasting can be done
within the forecast time horizon because behavior in that time zone is
mostly determined by past and present conditions, and can not be changed
abruptly by random events.
However, in the forecast time horizon, changes in decisions likewise can
produce little change. Changes take time. A changed decision can be
viewed as a random event the effect of which will be most influential
beyond the forecast time horizon. Using forecasting for controlling the
system is caught in a time trap. One can forecast within the forecast time
horizon, but momentum of the system will keep decisions based on the
forecast from being effective within the time frame for which the forecast
is valid. Decisions become effective in the action region beyond the
horizon of the forecast.
To exaggerate only a little, one can forecast in the time frame where one
can not act, and one can act in the time frame in which one can not
forecast.
The limits on forecasting future events suggest that one should instead
focus on forecasting how policies will change the character of system
behavior as discussed in the accompanying email.
Content-Type: multipart/appledouble; boundary="============_-1302151623==_D============"
--============_-1302151623==_D============
Content-Transfer-Encoding: base64
Content-Type: application/applefile; name="%JWF040.Forecast_vs_action.doc"
Content-Disposition: attachment; filename="%JWF040.Forecast_vs_action.doc"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Content-Type: application/msword; name="JWF040.Forecast_vs_action.doc"
; x-mac-type="5744424E"
; x-mac-creator="4D535744"
Content-Disposition: attachment; filename="JWF040.Forecast_vs_action.doc"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--============_-1302151623==_D============--
Jay W. Forrester
Professor of Management, Emeritus
and Senior Lecturer, Sloan School
Massachusetts Institute of Technology
Room E60-389
Cambridge, MA 02139
tel: 617-253-1571
fax: 617-258-9405
jforestr@MIT.EDU>
--============_-1302151624==_============--
Locked
