Get subranges?
linear feedback
Get subranges?
Post by linear feedback »
I can use GET SUBSCRIPTS to read in subscripts but how can I add or map subranges to it if the names of subscripts are not known in advance?
Re: Get subranges?
Can you upload a simple model demonstrating what mapping you need to do? There may be a way to do it.
linear feedback
Re: Get subranges?
I'd like to map the subranges in column B to the range in A. Trouble is that the number of elements in the subrange categories can change and should adjust itself to the data sets. Any thoughts?
Subrange.xlsx
(8.75 KiB) Downloaded 345 times
subrange.mdl
(1.16 KiB) Downloaded 328 times
Re: Get subranges?
Can you work with these files?
Read in the subscripts as before, but create a cross reference matrix. Then use this as a multiplier to convert
subrange.mdl
(2.06 KiB) Downloaded 327 times
Subrange.xlsx
(10.95 KiB) Downloaded 335 times
linear feedback
Re: Get subranges?
Thank you for your suggestion. As I would be dealing with 700 x 70 items a matrix does get a bit more complex in Excel. I have attached a solution which uses indexed subscripts - as one cannot calculate (especially references) with subscripts in vensim I use variables for doing so. Any thoughts which approach is better?
Is there a way around the necessity to call GET SUBSCRIPT with two fixed cell references? Using a different data set with a different structure requires also changing the model which a user won't like doing.
Subrange.xlsx
(11.08 KiB) Downloaded 321 times
subrange v3.mdl
(2.48 KiB) Downloaded 351 times
Re: Get subranges?
I'll raise this a feature request.
Regarding which method is better, it's really a matter of personal preference (and ease of understanding).
