delay fixed? how to use it
sally
Post by sally »
i have a problem,
when the prodution start , it will become under construction(level), then wait for 30 days(productino time), it will become the "production completed", so i need to use the delay fixed to desrcibe,
but the result seems wrong, hope some one can help me
thank you
the attachment is the file
(if i add the red line, and delete the under construction to completed line, the result seems right, but two rates can't connect direcetly? right)
[Edited on 1-1-2007 by sally]
production delay.mdl
(2.4 KiB) Downloaded 557 times
Can you post the model that you are using?
sally
Post by sally »
i have add the model in the first post
thank you
I believe the equation for "production completed" should be
production completed =
DELAY FIXED ( production start, REVIEW TIME + LEAD TIME , 0 )
You should read up about delay functions, there is lots of info in the Vensim manual.
All the best,
