HI
Here is th model joined.
if somebody does not understand it, just ask.
I could not upload the published model?
i download the .mdl
model about the staircase elevator problem exposed by Tom in the facebook forum
- option rest in the staircase.vdfx
- (16.96 KiB) Downloaded 317 times
- option rest in the elevator.vdfx
- (16.55 KiB) Downloaded 379 times
- staircase5.mdl
- (7.73 KiB) Downloaded 377 times
another better model about the staircase problem
A better version 6 that adds the calculation of the resting time in the elevator, especially if the starting time of the rest is close to the end of the climbing the elevator. It renames too most of the auxiliaries to initials, which is clearer. It calculates as initial the total time spent, showing that SD or capitalisation is not necessary to calculate it contrarily to the method used in the version 5. I have added another model version 7 with only two time-steps, that does not use any stock and where all the auxiliaries and stock of the version 5 are suppressed. The best way to use the model is with synthesim varying the ‘time starting the rest’ on the blue shadow variable. Both new models can be downloaded from the Vensim forum author LAUJJL.
Best
Best
- staircase7.mdl
- (9.56 KiB) Downloaded 330 times
- staircase6.mdl
- (12.16 KiB) Downloaded 365 times
Re: model about the staircase elevator problem exposed by Tom in the facebook forum
Interesting. I haven't really absorbed this yet, but my approach is quite different. https://metasd.com/2022/02/escalator-solutions/
