model about the staircase elevator problem exposed by Tom in the facebook forum
HI
Here is th model joined.
if somebody does not understand it, just ask.
I could not upload the published model?
i download the .mdl
option rest in the staircase.vdfx
(16.96 KiB) Downloaded 338 times
option rest in the elevator.vdfx
(16.55 KiB) Downloaded 404 times
staircase5.mdl
(7.73 KiB) Downloaded 404 times
another better model about the staircase problem
A better version 6 that adds the calculation of the resting time in the elevator, especially if the starting time of the rest is close to the end of the climbing the elevator. It renames too most of the auxiliaries to initials, which is clearer. It calculates as initial the total time spent, showing that SD or capitalisation is not necessary to calculate it contrarily to the method used in the version 5. I have added another model version 7 with only two time-steps, that does not use any stock and where all the auxiliaries and stock of the version 5 are suppressed. The best way to use the model is with synthesim varying the ‘time starting the rest’ on the blue shadow variable. Both new models can be downloaded from the Vensim forum author LAUJJL.
Best
staircase7.mdl
(9.56 KiB) Downloaded 360 times
staircase6.mdl
(12.16 KiB) Downloaded 394 times
Re: model about the staircase elevator problem exposed by Tom in the facebook forum
Interesting. I haven't really absorbed this yet, but my approach is quite different. https://metasd.com/2022/02/escalator-solutions/
