Vensim error: unable to read commands from .cmd
Amelys
Post by Amelys »
I'm using Vensim DSS 10.3.2. I'm trying to run a command script through a .cmd file and either a .bat file or a VBA script to launch Vensim. However, when Vensim launches, this error message appears:
When I open the command file directly in the Vensim interface via 'File > Open Model', the simulation runs without any issues.
I don't understand why this error message appears when I try to launch the command file outside of the Vensim interface.
Here is my commands lines:
SPECIAL>NOINTERACTION
SPECIAL>LOADMODEL|model_test.mdl
SPECIAL>CLEARRUNS
MENU>TAB2VDF|IN_test.tab|||
SPECIAL>CLEARRUNS
SIMULATE>DATA|IN_test.vdfx
SIMULATE>RUNNAME|Scen_test
SIMULATE>SETVAL|INITIAL TIME = 2000
SIMULATE>SETVAL|FINAL TIME = 2050
MENU>RUN|o
SPECIAL>CLEARRUNS
MENU>EXIT
Re: Vensim error: unable to read commands from .cmd
That looks like you are passing a blank filename to Vensim. Can you debug you vba to see what you are actually running?
Amelys
Post by Amelys »
I've checked my VBA code, and it does refer to the name and path of the .cmd file that I tried to launch. As this did not work with a simple .bat file either, I don't think the error comes from my VBA code.
I've tried this line of command in my .bat file
START C:\PROGRA~1\Vensim\vendss64MC "test.cmd"
Can you upload your test case?
