Simulation setup(Input Datasets)
Hi, i cannot find detail information about "Input Datasets" function in simulation setup. I tried to load datasets but they didn`t work. Is anybody can help me with it? thanks
Re: Simulation setup(Input Datasets)
Vensim PLE cannot make use of external data.
What versions of Vensim can do it?
You would need PLE+, Pro or DSS.
The following website has a comparison between the various versions.
http://vensim.com/comparison/
Vensim PLE can import datasets in the .dat format, for display alongside simulation results. See the Model>From .dat format... menu item. You can't use it to drive the model behavior though.
You can put driving data in a lookup, which is fairly easy copy-paste from a spreadsheet.
Using a more advanced version gives you a lot more power and convenience.
